August 29Aug 29 I was able to upgrade Roundcube from 1.5.15 to 1.6.18 on CWP 1.10 and AlmaLinux 9.Got the following during install:NOTICE: New .htaccess file saved as .htaccess.new.Running update script at target...WARNING: Replaced config options:(These config options have been replaced or renamed)- 'default_host' was replaced by 'imap_host'- 'smtp_server' was replaced by 'smtp_host'Do you want me to fix your local configuration? (y/N)- backing up the current config file(s)...- writing /usr/local/cwpsrv/var/services/roundcube/config/config.inc.php...Done.Your configuration files are now up-to-date!Executing database schema update.Updating database schema (2021081000)... [OK]Updating database schema (2021100300)... [OK]Updating database schema (2022081200)... [OK]This instance of Roundcube is up-to-date.Have fun!All done.Then restarted cpwsrv.I can get to the /webmail URL, and the Roundcube login screen comes up.BUT when you enter the UN & PW, it takes you to the servers home screen instead of logging you into Roundcube.Anyone have any ideas?Thanks Edited August 29Aug 29 by Starburst
