February 20Feb 20 This phenomenon typically occurs after a MariaDB upgrade.Typical log fragments in the maillog:warning: connect to 127.0.0.1:10031: Connection timed out warning: problem talking to server 127.0.0.1:10031 451 4.3.5 Recipient address rejected: Server configuration problem install_driver(mysql) failed: Can't locate DBD/mysql.pmThis indicates that cbpolicyd (Cluebringer) cannot load the required Perl database driver.Root CausePolicyd relies on a Perl DBI driver to connect to its MariaDB/MySQL backend. If the DBD::mysql module is removed or mismatched, Policyd child processes exit with status 2, and Postfix rejects all RCPT requests due to policy service timeout.AlmaLinux 8 vs AlmaLinux 9 BehaviorAlmaLinux 8 (EL8)Policyd requires:perl-DBD-MySQLThe configuration remains in /etc/cbpolicyd/cbpolicyd.conf DSN=DBI:mysql:database=postfix_policyd;host=localhostInstalling perl-DBD-MySQL resolves the issue.AlmaLinux 9 (EL9)EL9 introduces a packaging change where installing perl-DBD-MySQL may attempt to pull MySQL 8 libraries that conflict with MariaDB.Instead, install:dnf install perl-DBD-MariaDBThen update the Policyd configuration:Edit:/etc/cbpolicyd/cbpolicyd.confReplace:DSN=DBI:mysql:database=postfix_policyd;host=localhostWith:DSN=DBI:MariaDB:database=postfix_policyd;host=localhostThis forces Policyd to load the DBD::MariaDB driver instead of DBD::mysql.After modification:systemctl restart cbpolicyd systemctl restart postfixKey TakeawayEL8 → install perl-DBD-MySQLEL9 → install perl-DBD-MariaDB and change the DSN driver in /etc/cbpolicyd/cbpolicyd.confFailure to update the DSN on EL9 will cause continuous Policyd crashes and complete mail flow disruption.This distinction is critical for maintaining stable CWP mail servers after MariaDB upgrades or package maintenance.
