ImageMagick install script for AlmaLinux 9.x and CWP
There was some change in the availability of ImageMagick, so the PHP 8.4 and 8.5 installation script needed to be corrected.
#!/bin/bash
# Detect PHP FPM version
PHPFPM="/opt/alt/php-fpm84"
if [ ! -e "${PHPFPM}/usr/bin/php-config" ]; then
    PHPFPM="/opt/alt/php-fpm85"
fi
PHPBIN="${PHPFPM}/usr/bin/php"
PHPCONFIG="${PHPFPM}/usr/bin/php-config"
PHPINIDIR="${PHPFPM}/usr/php/php.d"
if [ ! -x "${PHPCONFIG}" ]; then
    echo "Skipping Imagick: php-config not found (${PHPCONFIG})"
    exit 0
fi
echo "Installing prerequisites..."
dnf -y install ImageMagick ImageMagick-devel ImageMagick-perl pkgconfig
cd /usr/local/src
rm -rf imagick-*
echo "Downloading imagick-3.8.1..."
wget https://pecl.php.net/get/imagick -O imagick.tgz
tar -xf imagick.tgz
cd imagick-*
echo "phpize..."
${PHPFPM}/usr/bin/phpize
echo "Configuring..."
./configure --with-php-config=${PHPCONFIG}
echo "Compiling..."
make -j"$(nproc)" && make install
EXTDIR="$(${PHPCONFIG} --extension-dir)"
if [ -e "${EXTDIR}/imagick.so" ]; then
    echo "Creating imagick.ini"
    echo "extension=imagick.so" > "${PHPINIDIR}/imagick.ini"
    echo "Imagick installation OK."
else
    echo "ERROR: imagick.so missing: ${EXTDIR}/imagick.so"
fi
The place of the script is:
/usr/local/cwpsrv/htdocs/resources/conf/el9/php-fpm_selector/external_modules/8.4
