April 17Apr 17 1 hour ago, Sandeep B. said:Tryrpm -e --nodeps mysql-common-8.0.41-1.module_el8.10.0+3965+b415b607.x86_64There are probably 20 of these conflicts
April 17Apr 17 On 6/2/2023 at 9:42 AM, Sandeep B. said:yum install MariaDB-server MariaDB-client net-snmp perl-DBD-MySQL -y Warning: failed loading '/etc/yum.repos.d/mariadb.repo', skipping. (this file is in the right location and has the following content: name = MariaDB baseurl = https://rpm.mariadb.org/10.11/centos/$releasever/$basearch module_hotfixes = 1 gpgkey = https://rpm.mariadb.org/RPM-GPG-KEY-MariaDB gpgcheck = 1 ) This is on a brand new server than my last failed attempt at doing this. I dont know what to say, except this is not working for alma8.
April 21Apr 21 Hi Sandeep,The upgrade went with a few hiccups but i managed to it working. when i do mysql -V it shows me mysql Ver 15.1 Distrib 10.11.11-MariaDB, for Linux (x86_64) using readline 5.1but after i did the command mysql_upgrade --forceand i scrolled up it gave me this :mysql.transaction_registry OKmysql.user OKPhase 2/8: Installing used storage engines... SkippedPhase 3/8: Running 'mysql_fix_privilege_tables'Phase 4/8: Fixing viewsmysql.userWarning : The user specified as a definer ('mariadb.sys'@'localhost') does not existstatus : OKsys.host_summary OKthe rest says all ok... behind.is this an issue or ?regardsMike
April 23Apr 23 On 4/21/2025 at 9:52 AM, Dutch_Mike said:Hi Sandeep,The upgrade went with a few hiccups but i managed to it working. when i domysql -V it shows me mysql Ver 15.1 Distrib 10.11.11-MariaDB, for Linux (x86_64) using readline 5.1but after i did the commandmysql_upgrade --forceand i scrolled up it gave me this :mysql.transaction_registry OKmysql.user OKPhase 2/8: Installing used storage engines... SkippedPhase 3/8: Running 'mysql_fix_privilege_tables'Phase 4/8: Fixing viewsmysql.userWarning : The user specified as a definer ('mariadb.sys'@'localhost') does not existstatus : OKsys.host_summary OKthe rest says all ok... behind.is this an issue or ?regardsMikeRecreate the user and try the upgrade again:CREATE USER `mariadb.sys`@`localhost` ACCOUNT LOCK PASSWORD EXPIRE; GRANT SELECT, DELETE ON `mysql`.`global_priv` TO `mariadb.sys`@`localhost`;
October 8Oct 8 While following the steprpm --nodeps -ev MariaDB-servergoterror: package MariaDB-server is not installedBut I continued and everything seems to be working.Hope its okay to ignore this error Edited October 8Oct 8 by siteur
October 11Oct 11 When upgrading from 10.1, 10.2, 10.3 to 10.11 to find the proper MariaDB repo you can use this service:curl -LsS https://r.mariadb.com/downloads/mariadb_repo_setup | sudo bash -s -- --mariadb-server-version="mariadb-10.11" Description:Link: https://mariadb.com/kb/en/mariadb/mariadb-package-repository-setup-and-usage/
